13 years ago
Test bench principle
When I write test bench for design simulation, I confronted some weird problems in GTL simulation. The results are similar, but I want to post here to discuss. For example, I have RAM, in testbench I input address to write or read like;
// example 1
always @(posedge clock) // posedge is active edge of the clock
begin
wren<=1;
address<=address+1;
data<=data+1;
end
// example 2
begin
rden<=1;
address<=address+1;
end
Sometimes, the Modelsim will give warning in each clock posedge to warn the setup and hold timing violation. And GTL simulation results are weird like the output data does not follow the sequence of address.
The Altera staff mentioned "Changing the data in a test bench at the exact same time as the active edge of the clock can produce unreliable and inconsistent results" , and he suggests don't use active edge of clock to change data or add delay like:
always @(negedge clock) // posedge is active edge of the clock
begin
wren<=1;
address<=address+1;
data<=data+1;
end
or
begin
wren<=1;
# 5 address<=address+1;
# 5 data<=data+1;
end
So I just have questions, when I writed testbench, I always change data using style:
always @(posedge)
begin
data<=f(data); // f(data) means a function of data
end
should I put timing delay in all these commands? And in testbench, blocking assignment and non-blocking assignment, which I should use? I think both of them work the difference are concurrent and one cycle delay.
Hope anyone can give me some advices. Thanks very much.
    You should use
    begin
    wren <=# (delay) 1;
    address <=# (delay) address+1;
    data<=# (delay) f(data);
    end
    where delay is what is needed to prevent timing violations. You want to put the delay to the right of the <= the delay is non-blocking; it only effects the delay of the assignment and not when the next statement executes.
    --- Quote Start ---
    You should use
    begin
    wren <=# (delay) 1;
    end
    --- Quote End ---
    Thanks very much for your help. So the# (delay) should be used for all assignments to prevent assignment happen exactly in active edge of clock, right?
    Could you explain a little more why put# (delay) in left not in right? Thanks very much.
    #delay statement;
    The blocks any statement, which includes an assignment statement. The process is blocked until the time the delay specifies.
    That statement can be a non-blocking assignment, which can have a delay that postpone the update to the RHS, but does not block the process. The next statement is executed immediately.
    # delay1 LHS <=# delay2 RHS;
    delay1 blocks the entire statement, delay2 only blocks the update to the RHS.
    See
    http://www.sutherland-hdl.com/papers/1996-cug-presentation_nonblocking_assigns.pdf
