Test a Verilog module via System Verilog
Trying to test a Verilog module via System Verilog. I'm analysing the RTL Simulation and I get the error: Error (10170): Verilog HDL syntax error at Test1.sv(29) near text: "program"; expecting a description.
I tried debugging it, but no results. It shows the error here after I instantiated the module I want to test.
interface valid_in1 (input clk); logic din; logic res; logic out; modport dut (input clk, din, res, output out); modport tb (input out, output clk, din, res); task monitor (); while (1) begin @(posedge clk); if (din==1'b1) begin $display ("@%0dns res %b out %b din %b clk %b", $time, res, out, din, clk); end end endtask endinterface: valid_in1 module valid (valid_in1.dut din); valid_in dut (.clk(din.clk), //the verilog module instantiation .din(din.din), .res(din.res), .out(din.out)); endmodule program validprog (valid_in1.tb tin); default clocking cb @(posedge tin.clk); endclocking initial begin fork tin.monitor(); join_none tin.res <= 1; tin.din <= 0; ##10 tin.res <= 0; ##1 tin.din <= 1; ##10 tin.din <= 0; ##5 $finish; end endprogram module Test1 (); logic clk= 0; always #1 clk++; valid_in1 cin (clk); valid dut (cin); validprog tb (cin); endmodule
I checked and it seems that the 3.4 Programs construct - whereby "The program building block is enclosed between the keywords program...endprogram", is currently Not supported in the Quartus synthesis tools.
To know more about the constructs supported. You may checkout the webpages below:
Verilog HDL Synthesis Support
SystemVerilog Synthesis Support
- RichardT_altera
SystemVerilog Synthesis Support- Petrov1
Worked as a charm in EDA Playground. Thank you
