13 years ago --- Quote Start --- FPGAs do not have USB ports. You will need to provide more details. What USB device is the FPGA connected to? --- Quote End --- I am using DE2-115 FPGA board which has integrated USB port (ISP1362). --- Quote Start --- If the USB device connected to the FPGA can be configured to enumerate as a USB-to-Serial converter, then you can use hyperterminal or teraterm (Windows). --- Quote End --- The problem is that serial port have very low data rate (around 115 kbps) and I need high data rate transfer (minimum 12 Mbps which is supported by its USB port as mentioned in user manual).
