- WGith
Hi, So I loaded your design and ran the commands you mention and they completed successfully. What would you like me to run next? The .tcl commands from the youtube video?
- WGith
- JonWay_altera
Hi @WGith
After you run the system console, run your STP, and look at the signals.
You should be able to see that the temperature and Voltage sensor IP to be working as expected.
The system console is to run the Temperature and Voltage sensor ip.
I reattached the stp just in case it was not included in the previous QAR.
I renamed the stp to txt, so that i can attach it. Rename it back to stp so that you can use it.
If there is one in the QAR, then just use that.
Thanks for the design. let me take a look into your design, and get back you later.
- WGith
Ok. So only the stp file works, right? I tried running the tcl scripts and neither worked. I'll try this in the morning. Thanks, Will - JonWay_altera
Run the tcl script, run the stp. Check the signals.
- WGith
The tcl scripts kept erroring for me. I'll send a screenshot tomorrow. - WGith
Hi, I haven’t had a chance to try your new image again with Signaltap. This will have to wait till Monday. Have you had any luck with my image? Thanks, --Will - JonWay_altera
Hi @WGith
I am taking a look into the design. I will update you when i have any findings.
Btw, what is the error you see running the tcl?
- WGith
Hi, I am out of the office till Monday day but I will give u the error then. Thanks, Will - JonWay_altera
Hi @WGith
May I know what is the error that you see when running the design i sent over previously? I have tested that design to be working. So if you can run the design, that would be great.
