RYang6
8 years agoTEMPERATURE SENSOR IP in STRATIX10 SX , READ INCORRECT VALUE
JonWay_altera
7 years agoHi @WGith
After you run the system console, run your STP, and look at the signals.
You should be able to see that the temperature and Voltage sensor IP to be working as expected.
The system console is to run the Temperature and Voltage sensor ip.
I reattached the stp just in case it was not included in the previous QAR.
I renamed the stp to txt, so that i can attach it. Rename it back to stp so that you can use it.
If there is one in the QAR, then just use that.
Thanks for the design. let me take a look into your design, and get back you later.
