Elpuri had already answered well. I will add this:
You don't mean Tco really. Tco is the clock edge to output transition time for a given register.
You probably mean one clock latency needed, so just add one more register at the output as follows:
ENTITY count_tia IS
PORT
clock: IN STD_LOGIC;
sload: IN STD_LOGIC;
data: IN integer RANGE 0 TO 127;
result: OUT integer RANGE 0 TO 127
END count_tia;
ARCHITECTURE rtl OF count_tia IS
SIGNAL result_reg : integer RANGE 0 TO 127;
BEGIN
PROCESS (clock)
BEGIN
IF (clock'event AND clock = '1') THEN
IF (sload = '1') THEN
result_reg <= data;
ELSE
result_reg <= result_reg + 1;
END IF;
result <= result_reg;
END IF;
END PROCESS;
END rtl;
