Most likely you have not set up your constraints correctly.
Read this document and look at the associated constraints files:
http://www.ovro.caltech.edu/~dwh/correlator/pdf/timequest_quad_spi_flash.pdf http://www.ovro.caltech.edu/~dwh/correlator/pdf/timequest_quad_spi_flash.zip Examples of MAX II Tco from that document are:
Info: TIMEQUEST: Slow process corner timing:
Info: TIMEQUEST: spi_sck : tco = 4.705 ns
Info: TIMEQUEST: spi_mosi: tco(min) = 5.397 ns, tco(max) = 5.926 ns
Info: TIMEQUEST: Fast process corner timing:
Info: TIMEQUEST: spi_sck : tco = 2.096 ns
Info: TIMEQUEST: spi_mosi: tco(min) = 2.532 ns, tco(max) = 2.898 ns
i.e., between 2ns and 6ns.
Cheers,
Dave
