GBraj
6 years agoTcl Error in Timing Analysis phase using LVDS SERDES RX IP
This is a new thread that continues another one found here (https://forums.intel.com/s/question/0D70P000006w2HT/tcl-error-error-argument-nodeobject-is-an-object-filter-that-matches-no-objects-specify...
KhaiChein_Y_Intel
6 years agoHi,
Kindly change the below:
In the file:
verilog_code/adc/adc_lvds_rx/altera_lvds_core20_191/synth/sdc_util.tcl
Change this line:
set fclk_name "${lvds_instance_name}${RX_NON_DPA_FCLK_TRAIL}"
To this line:
foreach_in_collection lvds_node [get_nodes -nowarn "$lvds_instance_name|*|fclk"] { set fclk_name [get_node_info -name [get_edge_info -src [get_node_info -clock_edges [lindex $lvds_node 0]]]]; break }
Note that if the IP is regenerated, you have to update this line in the SDC again.
KhaiY
