zener
2 years agoTcl command to run "Tools/Generate Simulator Setup Script for IP..."?
Is there a quartus_sh Tcl command or script to do the equivalent of selecting "Tools/Generate Simulator Setup Script for IP..." in the Quartus GUI? The scripts which are generated by qsys-generate (...
zener
2 years agoIt appears that the ip-make-simscript output is identical to the "Tools/Generate Simulator Setup Script for IP..." menu entry when passed a set of SPD files in xml format.
This is a bit more helpful than the GUI as it can be run in batch in a continuous integration type of environment where simulations are running concurrently in different directories.
However, it would have been easier to integrate in a current simulation environment if the information in the tcl scripts like suppress options, library names and paths, possible items to add to LD_LIBRARY_PATH, etc. I would still like to know if such a feature exists?
