RZhen11
6 years agoTcl command to generate HDL from .qsys, .qip
I have a project created with Quartus generated .tcl. At the beginning all added .qsys .qip files doesn't have HDL generated. Is there a .tcl command I can call to regenerate all the IPs? As of now...
KhaiChein_Y_Intel
6 years agoHi,
You can use qsys-generate to generate Qsys output files outside of the Qsys GUI. You can use qsysscript to create, manipulate or manage a Qsys system with command-line scripting.
Reference: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qsys_intro.pdf (Chapter Using Qsys Command-Line with Utilities and Scripts)
