11 years agoI have the same problem, that I get no input from the GPIO pins of the de1. Output is no problem and I can measure the voltage. But when I want to use a gpio pin as input, it is always tied to ground. I tried an external pull-up resistor as well as the internal pull-up resistor, but it doesn't change anything. For testing I use one of the leds for signalling. When I use on of the switches as input everything works fine. Has anyone some idea or had the same problem and solved it?
