15 years agoQuartus being a Synthesis tool it will very likely not support SV-DPI - DPI is meant for function/task level interaction bet'n SystemVerilog and foreign languages(s) 9with C defined as of today, C++ can be used, potentially can be extended for other languages such as MATLAB/VHDL etc. - depends on user inputs).
If you still need an example, look in www.verificationguild.com for few examples. Or there are several online tutorials that can get you started. Good Luck Srini www.cvcblr.com/blog
