17 years ago --- Quote Start --- Thank you. I see now that generic interfaces simply use 'interface' (like some object-oriented languages which derive all classes from 'Object') and that type-compatibility is checked at instantiation (rather than constructing a 'full' type hierachy and deriving from the most appropriate, so that type-compatibility can be checked when the subsidiary module is compiled). --- Quote End --- Exactly.. one thing to remember, be sure that all of you interfaces are first in the compile list. Quartus must see the interface before it sees the instantiation. This applies to packages as well.
