15 years agosystem verilog in Quartus
I can't understand system verilog.
I'm make two interfaces:
typedef struct {
logic dma_start;
logic dma_end;
logic dma_status;
logic dma_ctrl;
}dma_rx_t;
interface regs_if;
dma_rx_t dma0_rx;
endinterface
interface pcie_rx_if;
logic rx_ack ;
wire rx_ws ;
wire rx_req ;
wire rx_desc ;
wire rx_data ;
wire rx_be;
wire rx_dv ;
wire rx_dfr ;
endinterface
make my module:
module artem_memio_if (
input bit clk,
input bit rstn,
regs_if regs,
pcie_rx_if pcie_rx
(* keep = 1 *) wire rx_bar_hit_n;
assign rx_bar_hit_n = (pcie_rx.rx_desc | pcie_rx.rx_desc) ? 1'b1 : 1'b0;
upper level module:
module altpcierd_cdma_app_icm
input rx_desc0 ,
regs_if regs();
pcie_rx_if pcie_memio_rx();
assign pcie_memio_rx.rx_req = rx_req0;
assign pcie_memio_rx.rx_desc = rx_desc0;
assign pcie_memio_rx.rx_data = rx_data0;
assign pcie_memio_rx.rx_dv = rx_dv0;
assign pcie_memio_rx.rx_dfr = rx_dfr0;
artem_memio_if artem_memio(
.clk(clk_in),
.rstn(rstn),
.regs(regs),
.pcie_rx(pcie_memio_rx)
But quartus say: --- Quote Start --- Error: Net "top_example_chaining_pipen1b:core|altpcierd_example_app_chaining:app|altpcierd_cdma_app_icm:chaining_dma_arb|pcie_memio_rx.rx_desc[129]", which fans out to "top_example_chaining_pipen1b:core|altpcierd_example_app_chaining:app|altpcierd_cdma_app_icm:chaining_dma_arb|pcie_rx_if:pcie_memio_rx|pcie_rx_if.rx_desc[129]", cannot be assigned more than one value Error: Net is fed by "top_example_chaining_pipen1b:core|altpcierd_example_app_chaining:app|altpcierd_cdma_app_icm:chaining_dma_arb|pcie_memio_rx.rx_desc[129]" Error: Net is fed by "top_example_chaining_pipen1b:core|altpcierd_example_app_chaining:app|altpcierd_cdma_app_icm:chaining_dma_arb|pcie_memio_rx.rx_desc[129]" Error: Net is fed by "top_example_chaining_pipen1b:core|altpcierd_example_app_chaining:app|altpcierd_cdma_app_icm:chaining_dma_arb|pcie_rx_if:pcie_memio_rx|pcie_rx_if.rx_desc[129]" Error: Net is fed by "top_example_chaining_pipen1b:core|altpcierd_example_app_chaining:app|altpcierd_cdma_app_icm:chaining_dma_arb|artem_memio_if:artem_memio|pcie_rx.rx_desc[129] --- Quote End ---
