15 years ago
system ID not found at target base address
Hi.
I'm new about quartus & nios..
I use quartus II, NIOS II 10.0 & Window7 32 & de2-70 fpga board.
I have no problem until quartus pin assign, hdl compile&analysis&synthesis, programmer(.sof), nios c code build..
but I've got a serious problem like this
: run -> run configurations -> "actual system id not found on target at base address" error, so i can't run software with fpga board..
I have no license quartus & nios tool,
but i use NIOS II/e CPU so i have no time_limited.sof file.
(because it's a free IP)
therefore it's not a problem related to license..
Please see the captured pics, and let me know the solution about this...
thank you in advance..
https://www.alteraforum.com/forum/attachment.php?attachmentid=2864
https://www.alteraforum.com/forum/attachment.php?attachmentid=2865
https://www.alteraforum.com/forum/attachment.php?attachmentid=2866
    Which target are you using ? DE2-70 or what? The tutorial comes with the package is not correct, you have to check the pin name and pin assignment if you are working on tutorial
    I've the same problem with my DE4-230 board...I don't understand what is the problem....
    Has Anyone solved that...???
    I've solved...I re-programmed the fpga with the .sof file and then I did the nios running procedure again...problem has gone....;)
