Altera_ForumHonored Contributor15 years agosystem ID not found at target base address Hi. I'm new about quartus & nios.. I use quartus II, NIOS II 10.0 & Window7 32 & de2-70 fpga board. I have no problem until quartus pin assign, hdl compile&analysis&synthesis, programmer(...Show Moremultiple-attachments.zip479 KB
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
