covfefe
1 month agoSystem Console master_read_memory fails above 7688 bytes on Agilex 5 (AXE5-Eagle)
A single master_read_memory of 7689 bytes or more never completes on an Agilex 5. It returns nothing, times out after 60 seconds, and leaves the JTAG channel closed so the next command fails too. 768...
ZiYingE_Altera
Contributor
17 days agoHi covfefe,
Would it be possible for you to share the other affected design that you mentioned?
This would help us investigate the issue further.
Thank you.
ZiYingE_Altera
