13 years agoI think you need to provide more information about exactly wat you are trying to do and from what environment.
::boardInit_rootport is not a SystemConsole built in command so it seems likely that a script has defined this command and then executed it. If we can work out what the contents of the command are then it should be fairly easy to debug what went wrong. I presume you're familiar with TCL - if not then a good place to start is http://www.tcl.tk/
