11 years agoThis error message means that the USB-Blaster II MAX device is not correctly connected to its soft logic in the FPGA. Have you connected the pins on the trace system to the appropriate pins on the device. Please check the USB_SDA and USB_SCL pins first.
It would help if you said which version of the software you are using, and which OS you are running on. The trace table view will not appear until SystemConsole has found a trace system in the hardware.
