15 years ago
synthsis problem
Hi ,
for a university project I programed ( VHDL) some program to test FPGA errors
under very noisy environments . the structure is built of (pseudo) random number generator--->simple ALU *2----> comparator to compare the results from the 2 ALU'2---> the output is one bit error when the results are not the same.
when I compile it in QUARTUS I see in the compilation report that the device only use the pins and no logic/LUT or anything else is being used.
do you have any idea why? / how to fix it?
thanks ...
    a signal called " inclk0" , the default input clock ...
    now i compiled it and it even didn't use the pll so you're probably right ,
    How do I fix it?
    thank you very much for all your help ...
    you need to connect the inclk0 to a pin on the device! Inclk0 is the input port of the PLL. You need to connect this to a pin on the chip, and provide that pin with an oscillator (this is the clock) on your actual hardware.
    already tried it... didn't work ( just to be sure ,is the symbol for clk pins is a step symbol ?)
    hi ,
    does anyone has any idea how to fix it?
    I'm starting to be desperate ...
    I dont mind even send it the entire project so U can review it...
    In the assignments editor - how do I force the compiler to implement code (or entity) ?
    thanks...
    For all readers interested in the review:
    In his design, Yaniv used a comparator, but the two paths to the comparator were identical and thus optimized away. So there was no logic left to drive for the clock.
    Bye, Ton
    Is it correct of the clock wave? How frequency of the clock? Is it locked of the Pll?
