12 years ago --- Quote Start --- Yeah the values for sig_1, sig_2, sig_3 are calculated based on the inputs and only based on the inputs can we know whether they are equal to 11111 or not. So during synthesis when no test bench is applied the values of the sig_1, sig_2, sig_3 is not known and hence the 'output' signal cannot be assigned with anything. Hence the warning message (10034): output port at <> has no driver . So once input vectors are given to the design it should be able to calculate all the values and assign 'output' with some value cuz the simulation is working fine in modelsim. Will the hardware work fine once its driven with inputs? Can you kindly let me know if I should ignore the warning (10034) message during synthesis ? Thanks a lot for your help. --- Quote End --- You don't actually need to specifically drive sig_1,sig_2,sig_3 for synthesis but they should be either inputs to your module or if internal be dependent on some other inputs. As long as the design has inputs then it implies the tool will know they could be any value. you cannot ignore the warning as it means synthesis sets output floating(no connection). It will help to see your module interface and how these signals are driven.
