18 years agoIs gen_reg the name of the project you created, or is it the top-level module in your design? If the top-level module isn't the project name, you need to explicitly tell Quartus otherwise. If you go to Assignments -> Settings -> General, you can change the name of the top-level module/entity of that project. You may have to then explicitly add the files, too. (Project -> Add Files)
