12 years ago --- Quote Start --- You want us to guess what's not working as intended? Obviously it can't infer RAM. Can you guess why? To give a hint, embedded RAM can only access one memory location at a time (in one clock cycle), maximum two if utilizing the dual-port feature. --- Quote End --- Thank for your reply. You are right. I think I am still not get used to HDL. So can I use a "case" statement and include the above mem[] respectively? Will that synthesis correctly? Thank you.
