fxmelvin
4 years agoSynthesis - Incorrect SystemVerilog interface parameter override
I have come across an issue where Quartus Pro (21.x) Synthesis incorrectly resolves an interface parameter to its default value rather than the value with which it should've been overridden by the in...
- 3 years ago
Hi @fxmelvin ,
FYI. The bug had been fixed and implemented in Quartus Pro Edition version 22.4 internal build. Tested and worked fine check the image below:
Kindly wait for the version release. Thank you for your patience.
Sheng
ShengN_altera
3 years agoHi @fxmelvin ,
Sheng
