12 years agoI solved the problem.
I put the entity to an extra file: ****************** File: SumAbsDifference_Entity.vhd ENTITY hk_SumAbsDifference is PORT ( clr_n : IN STD_LOGIC; clk : IN STD_LOGIC; ... ); END hk_SumAbsDifference; ****************** and the two architectures (without entity ) in the two files ****************** File: SumAbsDifference_Arch00.vhd ARCHITECTURE arch0 OF hk_SumAbsDifference IS signal referenceDataArray : hk_TemplateArray; BEGIN ... END arch0; ****************** File: SumAbsDifference_Arch01.vhd ARCHITECTURE arch1 OF hk_SumAbsDifference IS signal referenceDataArray : hk_TemplateArray; BEGIN ... END arch1; ****************** The configuration I had to put into the .vhd where the component is instantiated. ****************** File: SingleTemplateMatching.vhd configuration cfg_TB1 of hk_SingleTemplateMatching is for ar1 for SumAbsDifference_tb : hk_SumAbsDifference -- use entity work.hk_SumAbsDifference(arch0); -- general n-Bit version NOT optimized use entity work.hk_SumAbsDifference(arch1); -- non lossy version 15 bit end for; end for; end; ****************** otherwise I would have to stepwise go through all the submodules (TL->Nios->DMAComponent->HWTop->...) and create configurations which one calls the other (like in: http://www.altera.com/support/kdb/solutions/rd07032012_70.html ) Thanks for your quick responses (the basic idea was, that a second entity definition is forbidden even if it is identical to the first). Kind regards
