its not work..same error appear same as usual..here is the lines..
gDelay: counterDelay port map (d, clk, q);
yDelay: counterDelay port map (d, clk, q);
and..the error are..
Error (10500): VHDL syntax error at allT.vhd(54) near text "port"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at allT.vhd(54) near text ";"; expecting ":=", or "<="
Error (10500): VHDL syntax error at allT.vhd(80) near text "port"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at allT.vhd(80) near text ";"; expecting ":=", or "<="
this is the declaration..
architec...
signal d, q : std_logic_vector(3 downto 0);
component counterDelay
port(D : in std_logic_vector(3 downto 0);
clk : in std_logic;
Q : out std_logic_vector(3 downto 0));
end component;
begin
and here is the component code..
library ieee;
use ieee.std_logic_1164.all;
entity counterDelay is
clk : in std_logic;
end counterDelay;
architecture dbehav of counterDelay is
begin
process(D, clk)
begin
if (clk'event AND clk = '1') then
if D = 15 then
for i in 1 to 15 loop
Q <= D;
end loop;
elsif D = 3 then
for i in 1 to 3 loop
Q <= D;
end loop;
end if;
end if;
end process;
end dbehav;
:confused:
