16 years agoHi,
I made a verilog module to instantiate each DW:module dw_add(/*autoarg*/ ... dw01_add# (ex_mul_partprod_bits) u_add (.a(a), .b(b), .ci(ci), .sum(sum), .co(co) ); endmodule Then I wrote a tcl script (for precision) to synt instance of DW:add_input_file ../dw_add.v set options[list "width 10"] setup_design -design dw01_add -overrides $options compile synthesize auto_write -format verilog dw01_add.v The first time I forgot to override parameter and I get a 4-bit adder (default value) which seemed to work on FPGA. But when I overrode parameter to 10 adder didn't work. DW netlist seems OK to me. Regards, Drackh
