16 years ago --- Quote Start --- Hello, Precision RTL Synthesis (Mentor) also supports DW. First I tried to make a netlist for each DW and then use complete Quartus flow but I didn't succeed. Finally I synthesize full chip with Precision and then Place & Route the netlist with Quartus. Thank you for your help. Drackh --- Quote End --- Hi, to choose a tool which supports the DW directly will deliver the best synthesis results, but on the other they are more expensive ( at least the Synplicty Tools). I'm interest in your problems by using the netlist for the DW. Can you explain it a little bit ? Kind regards GPK
