16 years ago --- Quote Start --- Hi, as far as I know you could not use Quartus for synthesis of DesignWare elements. I had a similar problem with ChipWare elements ( that are the corresponding elements from Cadence). I generated a netlist for each element. When you use Certify from Synopsys (former Synplicity) as synthesis tool, you can use directly the DesignWare elements. Maybe SynplifyPro supports DesignWare elements also. I have to check that. Kind regards GPK --- Quote End --- Hi, only Certify and Synplify Premier supports Designware elements. Kind regards GPK
