--- Quote Start ---
in an old project I have to maintain, I have many .bdf files where *.tdf modules are inserted as a "Symbol as block" (see attached picture).
I wonder if there is some documentation about these kind of *.bdf files. It is not obvious for me which signals are connected to each other. I had to look into the netlist viewer to confirm the interconnections between the symbols "_decode" and "_counter". I think in a *.bdf file the signalrouting should be more obvious.
Are the interconnections set automatically when the port names of two blocks are the same? E.g. the _win signals are the output of one block and the input of the other. Is there a rule that these signals are connected automatically?
Maybe somebody can explain a little bit what the use of these "Symbols as block" is because to me it is very confusing.
Thank you,
Maik
--- Quote End ---
Hi Maik,
I'm not so familiar with this kind of connections, but I think the connection is done by name. The two additional conduit boxes are required, because the name different between the block and the bus. ( block "_TX", conduit "_TX_DELAYED")
you can find more info's under :
http://www.altera.com/literature/hb/qts/quartusii_handbook.pdf?gsa_pos=3&wt.oss_r=1&wt.oss="symbol%20block"
search for "conduit" in the document.
Kind regards
GPK
