13 years agoSXT Error
I'm porting some old Xilinx code to Altera and I'm hitting an error.
When using the SXT function in the following code, I'm receiving an error. --code sum_azp_180(16 downto 0) <= (('0' & X"7080") + SXT(az_phase, 17)); --error Error (10621): VHDL Use Clause error at file.vhd(259): more than one Use Clause imports a declaration of simple name ""+"" -- none of the declarations are directly visible Error (10784): HDL error at file.vhd(36): see declaration for object ""+"" I have the following libraries included in the vhdl file. library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; use IEEE.STD_LOGIC_SIGNED.ALL; use IEEE.STD_LOGIC_MISC.ALL; use IEEE.NUMERIC_BIT.ALL; Any suggestions? Thanks
