16 years ago
Suspend Quartus processing
How can I suspend Quartus (9.0 sp2) compilation process?
It seems I can only interrupt it and then I need to restart from beginning.
If I need to use the computer a little while for another task during compilation I must face long delays: the pause-restart function would be very helpful.
Another question: if I change only pin or timing assigments in a design, is it mandatory that Quartus needs rebuild the entire project from scratch?
I expected some tasks could be skipped (i.e. analysis and synthesis) since design logic has not changed.
    There is no way to suspend it, sadly. Note that you can go to Tools -> Options -> Processing and tell Quartus to run as a lower priority thread. For a single CPU machine this is great, since it keeps things like email/internet very fast, but allows Quartus to run in usually the same amount of time. The only downside is if you run something else compute intensive, like a modelsim simulation, it will completely hog the CPU.
    For the second one, Assignments -> Settings -> Compilation Process -> Smart Compilation will try to skip modules that can be skipped. It's not perfect though. You can also go to Assignments -> Design Partition Window and set the top-level partition to Post-Synthesis, which tells it to skip synthesis when it can. I don't think this is available in web edition versions though.
    Finally, note that synthesis is now timing driven, so technically a timing assignment should require all modules to be re-run. It's probably fine to skip synthesis in most cases, but something to be aware of.
    i requested a pause feature once. i think the explanation was that it would be difficult to implement, getting to a "safe" stopping point and dumping all of the RAM contents to disk.
    i have used Quartus in a virtual machine to "pause" the compilation by putting the VM into a "saved state".
    That's correct pancake. The VM method is a good one if you don't mind the ~3% compilation slowdown running Quartus II virtually. It's easier for the VM to dump the contents to disk since it's performed at a higher level layer managed by the VM software.
