support for Agilex SoC Dev Kit DK-SI-AGI027FB in Quartus Prime Pro
- 3 years ago
The board you are using now is not in the board compilation list, however you can still compile if you select the exact part number of the device you have on the board. Currently the board you are using is not available from the selection list, however, it will be available in future Quartus version. The only benefit if you have board selection in the compilation setting is the pin assign will be set as the board pin assignment.
Board selection:
Device Selection:
If you have selected the correct part number as above, your compilation will run correctly, and it can be uploaded into the device on your devkit without any problem.
For current situation, we can't do anything to enable the DK-SI-AGI027FB board in the board selection list, until it is available in future Quartus version.
regards,
Farabi
Hi Bill W.,
Is this device that you have? would like to get your confirmation. It seem like it does have in Quartus Prime Pro Edition for AGIB027R31B1E1VAA.
Thank You
ELINA
- WWood73 years ago
Yes, that is right. I know that Quartus has that and that is what I am using. I am asking about the supported board(s). If you look at your other screenshot, the one with the "Board" tab open, you will see in the "device" column that a different FPGA part is listed. I believe that it is a different version of the board that I have.
Thank you. I am sorry for all the questions.
- Farabi_Altera3 years ago
Board selection:
Device Selection:
regards,
Farabi
