support for Agilex SoC Dev Kit DK-SI-AGI027FB in Quartus Prime Pro
- 3 years ago
The board you are using now is not in the board compilation list, however you can still compile if you select the exact part number of the device you have on the board. Currently the board you are using is not available from the selection list, however, it will be available in future Quartus version. The only benefit if you have board selection in the compilation setting is the pin assign will be set as the board pin assignment.
Board selection:
Device Selection:
If you have selected the correct part number as above, your compilation will run correctly, and it can be uploaded into the device on your devkit without any problem.
For current situation, we can't do anything to enable the DK-SI-AGI027FB board in the board selection list, until it is available in future Quartus version.
regards,
Farabi
Hi
Below here i try repost my previous replied :
1) Go to this link : https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/agilex/si-agi027.html
2) Download DK-SI-AGI027FB( v23.1 or higher) from Table 3 Documentation
3) After finish download folder , may open golden top folder. The .qsf here will have all the FPGA pin connections as on dev kit. Use as required. Remove/comment rest of the pins. :
below screenshot that i attached for your references:
Thank you
ELINA
Dear Elina,
Thank you! I can see the images and I received your e-mail with the same information.
The device I have is AGIB027R31B1E1VAA. This is not the same device as the one you list. This is why I initially posted my question. It appears that Quartus supports the DK-SI-AGI027FES board. I have the DK-SI-AGI027FB board. Are all settings are the same on the two boards?
Best wishes,
Bill W.
