support for Agilex SoC Dev Kit DK-SI-AGI027FB in Quartus Prime Pro
- 3 years ago
The board you are using now is not in the board compilation list, however you can still compile if you select the exact part number of the device you have on the board. Currently the board you are using is not available from the selection list, however, it will be available in future Quartus version. The only benefit if you have board selection in the compilation setting is the pin assign will be set as the board pin assignment.
Board selection:
Device Selection:
If you have selected the correct part number as above, your compilation will run correctly, and it can be uploaded into the device on your devkit without any problem.
For current situation, we can't do anything to enable the DK-SI-AGI027FB board in the board selection list, until it is available in future Quartus version.
regards,
Farabi
Hi
Good day,
Sorry for taking long time to reply. After discussion with my internal team, you may follow step like below :
1) Go to this link : https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/agilex/si-agi027.html
2) Download DK-SI-AGI027FB( v23.1 or higher)
3) After finish download folder , may open golden top folder. The .qsf here will have all the FPGA pin connections as on dev kit. Use as required. Remove/comment rest of the pins. :
select below screenshot that i attached for your references:
Thank you
ELINA
Thank you for the information. I have already taken those steps, and although my code does compile and load, I wasn't sure everything was correct.
I wonder if you could repost the screenshots? I cannot view them. (I am using the Chrome browser, version 116.0.5845.141. Should I use another?)
Best wishes,
Bill W
- WWood73 years ago
