support for Agilex SoC Dev Kit DK-SI-AGI027FB in Quartus Prime Pro
- 3 years ago
The board you are using now is not in the board compilation list, however you can still compile if you select the exact part number of the device you have on the board. Currently the board you are using is not available from the selection list, however, it will be available in future Quartus version. The only benefit if you have board selection in the compilation setting is the pin assign will be set as the board pin assignment.
Board selection:
Device Selection:
If you have selected the correct part number as above, your compilation will run correctly, and it can be uploaded into the device on your devkit without any problem.
For current situation, we can't do anything to enable the DK-SI-AGI027FB board in the board selection list, until it is available in future Quartus version.
regards,
Farabi
OK, thank you!
