13 years agoI agree with Tricky. Underflow and overflow occurs naturally when perform add and substract operations. If you perform a simulation with Model Sim you see that "0000" - "0001" gives "1111" ( underflow ). Try the testbench:
uut : entity work.sumador_2 port map( a => tb_a, s => tb_s ); process begin wait for 1ms; for i in 0 to 15 loop tb_a <= std_logic_vector(to_unsigned(i, 4)); wait for 1ms; end loop; assert false report "Fin de la simulacion" severity failure; end process; Where sumador_2 is: architecture data_flow of sumador_2 is begin s <= std_logic_vector( unsigned(a) - "0001"); end architecture data_flow;
