AKhan88
6 years agoStuck on the error: Verilog HDL Defparam Statement error at <location>: value for parameter "<name>" must be constant expression
Hi, I'm trying to support the synthesis of my system on both Vivado and Quartus. So far i've had tough luck with Quartus (probably due to my inexperience). I have a package in which i have some fun...
AKhan88
6 years agoI am using Quartus Prime 18.1 (standard). I've found the problem. Apparently for Quartus, having a declaration and initialization on the same line (e.g int a = 10 -> Quartus treats this as a non-constant expression) is different from having a separate line for variable declaration and initalization (int a; a = 10; ->Quartus apparently likes this). This is very bizarre. I don't fully understand why this is the case.
