struct -> how to add to SignalTap ?
Hi All,
Is it possible to add the struct signals to SignalTap? I did a search for the struct signals in the SignalTap GUI, but nothing was returned...
Thanks!
Yes, so as I said, why don't you just tap the right hand side signals?
- sstrell
What is a struct signal? Do you mean like a structure in C code?
- amildm
Contributor
yes, I used this struct:
typedef struct packed { logic clk; logic rst; logic de; logic hsync; logic vsync; } hdmi_if_s;here are the declared signals:
hdmi_if_s hdmi_rx_if; hdmi_if_s hdmi_tx0_if; hdmi_if_s hdmi_tx1_if;here are the signal assignments:
assign hdmi_rx_if.rst = reset; assign hdmi_rx_if.clk = hdmi_rx_vid_clk; assign hdmi_rx_if.de = hdmi_rx_de; assign hdmi_rx_if.hsync = hdmi_rx_hsync; assign hdmi_rx_if.vsync = hdmi_rx_vsync; assign hdmi_tx0_if.rst = reset; assign hdmi_tx0_if.clk = hdmi_tx0_vid_clk; assign hdmi_tx0_if.de = hdmi_tx0_de; assign hdmi_tx0_if.hsync = hdmi_tx0_hsync; assign hdmi_tx0_if.vsync = hdmi_tx0_vsync; assign hdmi_tx1_if.rst = reset; assign hdmi_tx1_if.clk = hdmi_tx_vid_clk; assign hdmi_tx1_if.de = hdmi_tx_de; assign hdmi_tx1_if.hsync = hdmi_tx_hsync; assign hdmi_tx1_if.vsync = hdmi_tx_vsync;In SignalTap, I searched for the signals with the "SignalTap: pre-synthesis" option, but they did not appear there ...
- sstrell
I've never tried this, but maybe the tool just sees them as busses. Can you tap hdmi_rx_if but not the individual bits by unique name?
- amildm
Contributor
tried... did not work...
- sstrell
What's your filter for the search? Did you try simply "*hdmi*"?
And I'm assuming you've performed at least Analysis & Elaboration on the project.
- amildm
Contributor
yes, I searched for "*hdmi*" and yes I performed the Analysis & Elaboration stage previously
- sstrell
Does the filter show the signals on the right side of your assignments like hdmi_rx_de?
- amildm
Contributor
yes.... only the struct is not shown ....
- sstrell
So can't you just tap those? The structure is just providing organization in your code. It's clearly not the physical names of the signals that get synthesized.
- sstrell
I don't understand. So the right hand side signals from your assignments appear in the Node Finder but you can't tap them? What happens when you try to tap them?
- RichardT_altera
Do you able to get the result you wanted by following sstrell's suggestion in tapping the right hand side signals?
Richard Tan
- sstrell
I don't understand. You can tap the exact signals that are in your struct, so why is it still an issue that you can't tap the struct itself? The signals are physical. The struct is for organizing in the code with no specific relation to the hardware.
If you go into the Technology Map Viewer, I will bet you will not see the struct names there either, further confirming they are not physical. Signal Tap can only tap actual signals.
- amildm
Contributor
"why is it still an issue that you can't tap the struct itself" - I don't know why... this is why I'm asking
Here is a simple example - the struct named 'ab' could not be seen/tapped in the 'top' hierarchy by SignalTap (only signals i0 and i1 could be tapped/seen):
//////////////////////////////////////////////////////////////////////////////////////////////////// package pkg; typedef struct packed { logic a; logic b; } ab_s; endpackage //////////////////////////////////////////////////////////////////////////////////////////////////// module top import pkg::*; ( input i0, input i1 ); ab_s ab; assign ab.a = i0; assign ab.b = i1; sub sub_i ( .ab (ab), .out() ); endmodule //////////////////////////////////////////////////////////////////////////////////////////////////// module sub import pkg::*; ( input ab_s ab, output logic out ); assign out = ab.a^ab.b; endmoduleBut inside of the 'sub' hierarchy, the signals ab.a and ab.b could be tapped/seen by the SignalTap.
- sstrell
Based on your example, I can only guess that physical signal names normally take priority (i0 and i1 are identical to ab.a and ab.b, respectively), but across a hierarchical boundary, if there is no physical signal name, the tool uses the struct because it has no choice. Try adding wires and assign statements inside sub to test this theory.
- amildm
Contributor
yes.... cannot tap ....
