amildm
Contributor
3 years agostruct -> how to add to SignalTap ?
Hi All,
Is it possible to add the struct signals to SignalTap? I did a search for the struct signals in the SignalTap GUI, but nothing was returned...
Thanks!
- 3 years ago
Yes, so as I said, why don't you just tap the right hand side signals?
sstrell
3 years agoBased on your example, I can only guess that physical signal names normally take priority (i0 and i1 are identical to ab.a and ab.b, respectively), but across a hierarchical boundary, if there is no physical signal name, the tool uses the struct because it has no choice. Try adding wires and assign statements inside sub to test this theory.
