13 years ago --- Quote Start --- In simulation, the design is working correctly. --- Quote End --- Ok, then you're looking for a hardware issue. --- Quote Start --- When I reduced the ADC width to 7 bit (Each ADC is using 28 LVDS pairs) then I am able to program All the ADCs and also working fine. When I include all the ADC width to 10 bit (Each ADC is using 40 LVDS pairs)then programming is failing at 97%. --- Quote End --- Did you look at the power supplies during this time? Eg. the 2.5V LVDS power rail or the FPGA core power supply? --- Quote Start --- Is there any limitation of using LVDS pairs in stratix iv FPGA? --- Quote End --- No, but you must have a power supply capable of delivering the current required for the design. Take your simulation, and provide toggling signals on each of the ADC inputs. Generate a .vcd file and perform a PowerPlay analysis on that file. See what Quartus predicts the power requirements of the design to be. Then check the power supply rating on your board. Cheers, Dave
