13 years ago --- Quote Start --- When I instantiate All four ADCs the programming is failing.... Can any body please help me in this why the programming is failing. --- Quote End --- What do you mean by failing? Does this design work correctly in simulation? If it does, then I would suspect something more like a hardware issue, for example, a power supply failing to supply enough current. Try a test where all four ADCs are included in the design, but the controls for each ADC are configured such that they are all disabled on power up (if such an option is possible). Then try enabling one ADC at a time, two ADCs, three ADCs, and finally four ADCs. If the last option also causes a failure, then look at your power supplies in more detail. Cheers, Dave
