17 years agopage 4-13:
--- Quote Start --- The widest bit configuration of the M9K and M144K blocks in true dual-port mode is as follows: ■ 512 × 16-bit (×18-bit with parity) (M9K) ■ 4K × 32-bit (×36-bit with parity) (M144K) Wider configurations are unavailable because the number of output drivers is equivalent to the maximum bit width of the respective memory block. Because true dual-port RAM has outputs on two ports, its maximum width equals half of the total number of output drivers. --- Quote End --- Thanks for making me feel better about not being the only one to miss it the 1st time thru. :) -Brian
