14 years ago --- Quote Start --- May you can set up Signaltap to focus on what happens at the start of packet? --- Quote End --- There is a start of a packet I've mentioned before. I trigger on start signal, but also 0x47 is a start byte. All start signals comes up with 0x47. I could also suffer from data writes to the middle of the packet when fpga powers up, this means, that 0x47 could anywhere, but not at the start place. I will try to do some safety logic here.
