I managed to create a workaround. Several days ago, I tried to instantiate the PFL megacore. I was consistently getting the invalid silicon ID on device 1 error after the bitstream was loaded to the FPGA. This seemed to be to me a problem with the PFL core not recognizing the flash as it is two dies stacked on top of each other with no knowledge of each other. I went ahead and changed the parameters to make it a 256 Mbit flash (512 total on the package), pulled the highest address bit high, regenerated my pof as a 256 Mbit file with changed addressing (user space starting at byte 0x1500000 instead of 0x3500000), and programmed the device according to Altera's directions. This time, verification succeeded, I saw no more unexpected 0xFF gaps in the data, and my OR1200 CPU core now boots.
I'm still curious as to why this works and why it seems as though no one else on the web has had this problem.
module stratix_iii_flash_prog_top (
input pfl_flash_access_granted,
input pfl_nreset,
output flash_addr,
inout flash_data,
output flash_nce,
output flash_noe,
output flash_nwe,
output pfl_flash_access_request,
output sram_ncs,
output sram_noe
pfl pfl0 (
.pfl_flash_access_granted(pfl_flash_access_granted),
.pfl_nreset(pfl_nreset),
.flash_addr(flash_addr),
.flash_data(flash_data),
.flash_nce(flash_nce),
.flash_noe(flash_noe),
.flash_nwe(flash_nwe),
.pfl_flash_access_request(pfl_flash_access_request)
assign flash_addr = 1'b1;
assign sram_ncs = 1'b1;
assign sram_noe = 1'b1;
endmodule
