Stratix III 3SL150 Holes in Flash
I have the Stratix III 3SL150 DSP dev board and have a problem programming flash. Whenever I program the Intel CFI device, the flash ends up having large sections (on the order of 20 or 50 words) initialized to 0xFF but not actually programmed. I checked with some RTL that I wrote to operate slowly at 10x+ the read timings (e.g. 1 MHz for my FSM) and verified the errors that the Quartus software was giving me. I have been following the instructions in the board's user guide and reference manual perfectly with regards to jumper settings and software settings. I am using the stratixIII_3sl150_dev_pfl.sof file from the "factory recovery" archive downloaded from Altera's site. I have tried both USB+CPLD and external USB Blaster methods of programming and get the same results.
Am I doing something wrong, or does this appear to be a hardware problem?
With the PFL pof file loaded, manually adding the CFI, and checking Program
and Verify for all items: the FPGA pof and the sof containing Page 0, image.hex,
and OPTION BITS. Quartus II 11.0.
Info: Started Programmer operation at Mon Jan 02 15:22:30 2012
Info: Configuring device index 1
Info: Device 1 contains JTAG ID code 0x121020DD
Info: Configuration succeeded -- 1 device(s) configured
Info: Device 1 CFI Flash 1 is PC48F4400P0VB00 (16 bits data bus)
Info: Erasing CFI Flash configuration device(s)
Info: Programming status: erasing flash device 1 (PC48F4400P0VB00) at device chain position 1
Info: Programming status: erasing flash memory at byte address 0x00000000
Info: Programming status: erasing flash memory at byte address 0x00008000
Info: Programming status: erasing flash memory at byte address 0x00010000
Info: Programming status: erasing flash memory at byte address 0x00018000
Info: Programming status: programming flash memory at byte address 0x03A90000
Info: Programming status: programming flash memory at byte address 0x03AA0000
Info: Programming status: programming flash memory at byte address 0x03AB0000
Info: Programming status: programming flash memory at byte address 0x03AC0000
Info: Programming status: programming flash memory at byte address 0x03FE0000
Info: Programming status: verify on flash device 1 (PC48F4400P0VB00) at device chain position 1
Info: Performing verification on device(s)
Error: Verify (address 0x03500000) failure on device number 1
Error: Operation failed
Info: Ended Programmer operation at Mon Jan 02 17:12:51 2012
In Quartus II 11.0, loading the PFL pof file, clicking Auto Detect, and checking Program
and Verify only for image.hex and OPTION BITS.
Info: Started Programmer operation at Mon Jan 02 17:34:37 2012
Info: Programming status: erasing flash memory at byte address 0x03500000
Info: Programming status: erasing flash memory at byte address 0x03FE0000
Info: Programming device(s)
Info: Programming status: programming flash device 1 (PC48F4400P0VB00) at device chain position 1
Info: Programming status: programming flash memory at byte address 0x03500000
Error: Verify (address 0x03500040) failure on device number 1
Info: Ended Programmer operation at Mon Jan 02 17:34:46 2012
In Quartus II 8.0, attempting the last thing that I tried in Quartus II 11.0.
Info: Started Programmer operation at Mon Jan 02 18:16:18 2012
Info: Device 1 CFI Flash is Intel 28F512P30 Bottom Boot (16 bits data bus)
Info: Programming status: reprogramming flash memory at byte address 0x03500000
Info: Ended Programmer operation at Mon Jan 02 18:16:26 2012
All comments are appreciated. Thanks.
