cmautner
1 year agoStratix 10 Programmer failure
I am trying to program a STRATIX10TX SIGNAL INTEGRITY development kit. I had created my first .jic file and it went through 100% programming cycle. Then it started to go through a second pass of prog...
FakhrulA_altera
1 year agoHi cmautner,
Apologies for the delay, I’ve been a bit tied up lately.
Have you tried programming the board using a SOF file or a new JIC file? Also, could you share what configuration scheme you're using for this application?
Since you mentioned that Quartus 20.1 and later versions fail, have you tried using an earlier version of Quartus? If so, what was the result?
Fakhrul
