17 years ago
Strange synthesis result , getting crazy
I am new to VHDL.
I am using Quartus II v.8 Web edition for synthesis.For several days i stuck at the following simple code.:(
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY clock IS
PORT
clk_in : IN STD_LOGIC;
triger : OUT STD_LOGIC
END clock;
ARCHITECTURE clock_architecture OF clock IS
BEGIN
PROCESS(clk_in)
variable second : INTEGER RANGE 0 TO 59:=0;
variable minute : INTEGER RANGE 0 TO 59:=0;
variable hour : INTEGER RANGE 0 TO 23:=0;
variable interval : INTEGER RANGE 0 TO 9:=0;
variable outtriger :STD_LOGIC :='0';
BEGIN
if(clk_in'event and clk_in='1') then
if second < 59 then
second:=second+1;
else
second:=0;
if minute <59 then
minute:=minute+1;
if interval<9 then
interval:=interval+1;
outtriger:='0';
else
interval:=0;
outtriger:='1';
end if;
else
minute:=0;
if hour<23 then
hour:=hour+1;
else
hour:=0;
end if; --end of hour
end if; -- end of minute
end if; --end of second
end if; -- end of clk'event
triger <= outtriger;
END PROCESS;
END clock_architecture;
When i watch the RTL after synthesis all the variable second, minute, interval converts to registers but i didn't find any register for hour.(I attached the RTL with this thread).But if i remove following code l can find the register representing hour in RTL.
if interval<9 then
outtriger:='0';
else
interval:=0;
outtriger:='1';
end if;
Plz ...plz ...plz help me if you can.:mad:
Thanks in Advanced
Raisul
http://www.velocityreviews.com/forums/images/statusicon/user_online.gif
    The synthesis tool recognizes that no output depends on the "hour" variable and synthesizes it away.
    The only input for the trigger output in the code you are evaluating is the minute signal, which is independent from the hour signal. So the hour does not need to be counted.
    If you create a dependency on the hour signal, lets say set the output to 1 in a specific hour only, then the hour will result in a register as well.
    Lokla
    Now i understand why my code was gerenating abnormal RTL.I created a dependency on the hour signal and the problem solved.
    Many Many thanks.I was stuck at this problem for more than a week.
