--- Quote Start ---
The pll takes a few cycles to lock in, meanwhile the output is undefined. If you add a locked output, then you will see the defined output appears when locked. Probably reset should be applied to the FIFO untill locked.
--- Quote End ---
Thanks for your answer. At least that cleared something. I did add a locked output, and my initial guess was that it needed some time to correctly generate the output. However I was expecting the output to be low rather than undefined during the locking phase.
Is there a way I could force the output to low while waiting to get a lock?
