17 years agoDear Vernmid
Thank you for your answer. When I put the simple assignment in the process as you suggest I got in the simulation undefined in the two first cycles and amazing in the other cycles the value of MostSignificant(MSA) was as the VectorOnes (MSA) in the previous cycle. I know it shouldn't happen according to VHDL instruction. In all the versions MostSignificant(MSA) is assigned only once. My amazement is because according to VHDL I shouldn't get any problem in both versions when the assignment is out the process and in the process. Best Regards Rami
